psj8890
Dec 26, 2017Follower
C6300 – AC1750 WiFi Cable Modem Router Wifi disappeared
Wifi Router C6300 – AC1750 WiFi Cable Modem Router Wifi disappeared. After restart the modem router, Wifi can be found and worked for a while then it suddenly disappeared from the wifi list and not ...
DarrenM
Dec 28, 2017Sr. NETGEAR Moderator
Have you tried to rename the network? or notice when the network goes away that a certain device is connecting to the network?
DarrenM
prasanths1989
Jan 02, 2018Aspirant
DarrenM To answer your question. I found a pattern like when ever I am turning my laptop (newly bought), this is happening, or if My laptop awake from sleep, this is happening. I am not confirming this but looks like there is a pattern, Need more testing.
But what is a solution?
THanks
Prasanth
