saint2468
Jan 12, 2022Aspirant
C6300 - Information only - Stuck on "Updating settings" while setting a static IP address
I encountered the same problem as this article (https://community.netgear.com/t5/Cable-Modems-Routers/C6300-Reservations-not-working/m-p/2032850/thread-id/29556). Basically, when the web interfac...
Jan 12, 2022Guru - Experienced User
What broswer are you using? Try MS Edge, Firefox or Opera?
Be sure to clear out any browse caches...
Has a factory reset and setup from scratch been performed yet?
saint2468
Jan 20, 2022Aspirant
Thanks for your feedback.
I tried using Chrome, Firefox, and Edge and they all had the same effect.
I didn't try clearing the browser cache but then I had never used Firefox and Edge to access the router before.
I didn't do a factory reset since it eventually worked by just waiting. :)
