iacopo
May 25, 2016Aspirant
C6300 5GHz band stops working
Hi, for the second time in a few days my brand new modem/router stopped broadcasting on the 5GHz band. The SSID for the band is still broadcasted, I can connect, but if I inspect the connection ...
DarrenM
May 27, 2016Sr. NETGEAR Moderator
Hello iacopo
If the modem keeps doing this you may want to contact netgear support if your modem is still under warranty.
http://www.netgear.com/support/contact.aspx?cid=gwmng
DarrenM
