iacopo
May 25, 2016Aspirant
C6300 5GHz band stops working
Hi, for the second time in a few days my brand new modem/router stopped broadcasting on the 5GHz band. The SSID for the band is still broadcasted, I can connect, but if I inspect the connection ...
vkdelta
May 27, 2016NETGEAR Employee Retired
Question: are you saying that 5GHz Radio stops broadcasting and only way to get it back up turning off the modem and turning it back after 60s?
If yes, please PM me.
