DarthMalgus
Jun 02, 2016Novice
C6300 5GHz Keeps Disconnecting
Hi all, I bought my Netgear AC1750 C6300 from Amazon June 19 of last year and loved it combined with my TWC. But just 2 days ago, my 5GHz wifi keeps shutting off on my desktop about 5-10 mins after ...
DarrenM
Jun 06, 2016Sr. NETGEAR Moderator
Hello DarthMalgus
Can you tell me what firmware version the modem is showing its typically located in the top right hand corner when you log into the modem.
DarrenM
