rehousejr
Apr 21, 2021Aspirant
C6300 AC1750 add another router or access point
Hi, I have a C6300 AC1750 and I wanted to hard wire another router or access point to an outside pool house so my pool area has better wifi. Can I do that and if so, how? Would any router or acce...
Apr 21, 2021Guru - Experienced User
yes you can wire in an access point or a router that supports access point mode.
Either would work. I've used multiple routers as access point and even some of the models of extenders support access point mode.
so you have many options.
- rehousejrApr 21, 2021Aspirant
Thank you very much for your input!
