netmask001
Jun 13, 2021Aspirant
C6300 AC1750 and xfinity 400MBps download plan
does this router support comcast 400Mbps download plan? The specs says up to 680Mbps download? but comcast is saying it only downloads at 384mbps
netmask001
so can i use the c6300 for a 400mbps download plan on xfinity?
Jun 13, 2021Guru - Experienced User
Can you use it on a 400mbps plan? sure.
Will it get 400mbps? not if xfinity doesn't support 400mbps on that device.
You could use it on a gigabit plan but it won't hit those speeds. its all wha the ISP provisions it for and supports.
