Retired_Member
May 18, 2021C6300 AC1750 Cable Modem Router
The Upstream light on the front of the device is always orange. I tried a reboot (on/off button on back). Firmware version 3.01.04 and Cox is my vendor. Otherwise the device seems to work properly...
Retired_Member
May 21, 2021Any Help?
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||
May 22, 2021Guru - Experienced User
that's the same upstream. Your downstream?
- Retired_MemberMay 22, 2021
Sorry, all 16 downstream bonded channels are locked.
- plemansMay 23, 2021Guru - Experienced User
Its not just "are they locked" its also the snr/correctables/uncorrectables
- Retired_MemberMay 23, 2021
Correctables & UnCorrectables
1 573 6123 2 21 623 3 1003 6556 4 897 6236 5 859 5617 6 924 6215 7 624 6368 8 1097 5883 9 769 6484 10 1193 5940 11 837 5890 12 650 6142 13 567 5965 14 1068 6043 15 1130 5645 16 644 6306 Current System Time: Sun May 23 09:48:48 2021System Up Time: 4 days 20:40:01
