Maggie0404
Nov 03, 2016Follower
C6300 AC1750 can't handle 300Mbps
We have WOW internet service. We currently have 110Mbps service. Everything is working good. When we upgraded to 300Mbps the modem would not accept that speed. The WOW customer service agent said t...
DarrenM
Mar 16, 2017Sr. NETGEAR Moderator
Hello Circadianswing
Do you have a older device that is not a 802.11AC device connected to the wireless this will pull the speed down on the wireless so try connecting your older devices to the 2.4ghz and your new ones on the 5ghz.
DarrenM
Retired_Member
Mar 30, 2017Hi Darren, I think what you said may be true.. 300mbps service from spectrum / time warner may need the 24x8 channel bonding, available in the newer nighthawk version of the router/modem. I moved on to an Arris 32 channel cable modem and tried a number of high end routers from other brands, only to have other issues with client wifi devices. In the end, I rolled back to 100mbps service with spectrum, and re-attached this modem/router combo. Everything works again. it was 2 weeks of unsuccessful testing.
