Buckeye57
Aug 16, 2022Aspirant
C6300 AC1750 Missing 5G Channel on one of two computers
This is a little confusing so I'll try to break it down. 1. I have the C6300 WiFi Cable Modem Router - Model C6300. It has two channels, 2.4GHz and 5G. 2. I have two laptops, a 2014 Dell (Window...
- Aug 18, 2022
Again, not sure what you were doing but you weren't connecting to the 5ghz with that wireless card. It has zero 5ghz capability. Its not something that a sneaky regedit/error can fix and cause it to suddenly see/connect to 5ghz. Its not possible because it requires the 5ghz hardware. And it doesn't have it.
Maybe you'd misnamed your ssid from the router and just "thought" you were connecting to 5ghz but its not possible for it to actually do so.
We can argue this all you want but it isn't going to get further than, "that card won't see 5ghz and won't be able to connect".
In terms of your 2.4ghz speed, try going in and change the wireless channel it uses. Also, if you live in a rural area, you can uncheck "enable 20/40 coexistence". If you live in an area with a bunch of wireless signals, than leave it enabled.
Aug 17, 2022Guru - Experienced User
What wireless card is in the device thats not working?
Does that device see other 5ghz networks?
Buckeye57
Aug 17, 2022Aspirant
Hi Plemans,
Thank you for responding. The wireless card is a "Dell Wireless 1705 802.11b/g/n (2.4GHz)". I realize that it isn't a 5GHz card, but the problem is, until a couple of weeks ago, I was connected to the 5GHz WiFi channel. When I look at the list of available networks, the C6300 is listed but the C6300-5G isn't listed any longer. There are other available 5G networks listed.
I ran a diagnostic and this is what it shows:
Profile: NG15
SSID: NG15
SSID length: 9
Connection mode: Infra
Security: Yes
Set by group policy: No
Connect even if network is not broadcasting: No
Connectable: Yes
Profile: NG15-5G
SSID: NG15-5G
SSID length: 12
Security: Yes
Connectable: No
Reason: 0x00028003
I've looked around online and can't find what "Reason: 0x00028003" means.
Does this info help?
Thanks!
- plemansAug 17, 2022Guru - Experienced User
Not sure what you were seeing before but you're right in that its only a 2.4ghz wireless card. It won't be able to pickup 5ghz signals.
Its not a "software" issue. Its hardware. It doesn't have the hardware capability.
so its not a router issue.
If you're wanting it to connect to 5ghz, you'd need to upgrade the wireless card to dual band. Some of those older laptops its pretty easy/cheap to upgrade ot dual band.
- Buckeye57Aug 17, 2022Aspirant
Thank you again for your assistance, Plemans.
I realized that I wouldn't be able to use the full 5GHz, but I was able to connect to it. I was getting better speed tests with it than I am with the 2.4GHz. I'll look into getting the upgraded card, but since I have an alternate (newer) laptop, I might just stick with what I have.
Strange thing is I just ran another speed test and I've gone from around 6 - 9 Mbps to 27.
Thank you again for your help and advice!
- plemansAug 18, 2022Guru - Experienced User
