Mike_in_Milton
Aug 23, 2022Initiate
C6300 AC1750 modem router stopped broadcasting 2.4GHz band
I purchased and installed a Netgear C6300 AC1750 modem-router combo last December and it worked well until several weeks ago when the 2.4GHz band disappeared, leaving only the 5.0GHz band broadcastin...
- Aug 25, 2022
Thank you, Plemans, for your recommendation. I followed your advice and the 2.4GHz band began broadcasting again. I subsequently went into the settings, renamed it and adjusted other settings to get the unit back where it was before it went AWOL.
A rhetorical question: Why did the Netgear "Support" person never suggest or even mention the possibility of my performing a factory reset? My guess is that once they determined the modem-router was past the 90-day free support period, they no longer cared to assist me unless and until I agreed to pay for the solution you so kindly provided.
In any case, Plemans, I'm happy to declare this case closed, and I thank you for your assistance.
Netgear makes good modem routers but I can't say the same for their Support department.
Aug 23, 2022Guru - Experienced User
A couple things.
1. While yes your warranty is 1 year, the actual support period for issues is 90 days. Meaning if its a hardware failure, it'll be replaced but if its a settings issue, it costs you $ as its not a hardware failure. So thats why they have that number. Once they found out you were out of the 90 days, its now a point where you pay for support until its determined its a hardware issue.
2. Did you try the old "nuke the world" option and just factory reset? Push and hold reset for 7-15 seconds while powered on? If when it reboots, the 2.4ghz isn't broadcasting, then it sure could be a hardware issue and you'd need to call the number to go through support.
3. This is the community support forum. We're not netgear. We know a lot of about it and can help diagnosis but keep in mind that we're not netgear.
4. Its rare to see netgear remote in to fix an issue. Usually when we see that, its a 3rd party site or a scam site. Not saying they don't but half the time, its cheaper for them to RMA a device then it is to remote in and troubleshoot.
Mike_in_Milton
Aug 25, 2022Initiate
- plemansAug 25, 2022Guru - Experienced User
I'd agree that their support could use a little work.
I'm pretty sure its down to just that they know they have to charge up front past that 90 days of users don't pay after a call. (hard to get payment after the fact)
I've had users report they've asked "does the power light come on green?" and if it does, they'll charge you for more help.
So its kind a crap situation and thats half the reason the community forum is so active. And why you'll see a lot of community forums for consumer networking gear.
