epx998
Aug 03, 2015Tutor
C6300 AC1750 Port Forward Not Working.
I have seen this in a lot of threads. I need to enable SSH port forwarding to a server here at home, but I have ran into the same problem has hundreds of others. Port forwading just plain doesn't w...
epx998
Aug 04, 2015Tutor
Hello Elaine,
Thank you for your reply.
I tried adding my server IP to the DMZ server configuration and it did not work. I also tried the hard reset before I posted with the same result, the modem will not port forward.
So end result, port forwarding SSH or HTTP does not work. This worked previously on my Motorola modem without issue.
