epx998
Aug 03, 2015Tutor
C6300 AC1750 Port Forward Not Working.
I have seen this in a lot of threads. I need to enable SSH port forwarding to a server here at home, but I have ran into the same problem has hundreds of others. Port forwading just plain doesn't w...
ElaineM
Aug 04, 2015NETGEAR Employee Retired
Hi epx998,
We apologize that the feature is not working as it should. As a suggestion, try to check if SSH will work on DMZ. This is just to verify that port forwarding feature has the problem. If you can get your SSH to work through DMZ feature, kindly try to reset and reconfigure the unit. Push the reset button on the unit for 20 seconds. Power light must be blinking when you reset it. Once done, reconfigure the unit and see whether port forwarding would work. Let us know what happens.
stringzz
Sep 13, 2015Aspirant
Hi Elaine, I am having same issue with c6300 router. I enabled DMZ on my computer and tried to SSH, no luck, cannot connect.
firmware: V1.02.19
- DarrenMSep 14, 2015Sr. NETGEAR Moderator
Hello Stringzz
We have seen quite of few customer experiencing the same issues as you I am currently having this investigated on what could be causing the issue I will let you know as soon as I hear back.
DarrenM
- dwatDec 07, 2015Initiate
Has a solution been reached for this problem? I see that there have been no updates for months and I would also like to resolve this issue.
