SonnyJr
Feb 12, 2023Aspirant
C6300 AC1750
I am trying to download firmware update for windows 10. It does not seem to be working. Any thoughts? Thank you
michaelkenward
Feb 12, 2023Guru - Experienced User
Thank you
What firmware update?
There are none that you can use for cable modems. That is down to the Internet service provider.
Neither you nor Netgear have any control over the C6300.
- SonnyJrFeb 12, 2023Aspirant
I noticed version V3.01.14 is available for download. Frequently, I am losing connection. I contacted my ISP and they suggested that it has to do with my modem.
Thank you
- FURRYe38Feb 12, 2023Guru - Experienced User
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-routerHave the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Thank you
- KitsapFeb 12, 2023Master
SonnyJr wrote:I noticed version V3.01.14 is available for download. Frequently, I am losing connection. I contacted my ISP and they suggested that it has to do with my modem.
Thank you
As an end user, you do not have the option to download or update firmware for your C6300.
See attached.
Your ISP wants you to rent their modem so to increase their revenue stream.
You mean the product is out of support now?
