jandainaz
Aug 24, 2020Aspirant
C6300 admin password not working
I am trying to connect to my C6300 router using the admin password. I am wired to the router and found that I can only get it to connect with Firefox (Chrome and IE did not work). After I go to route...
jandainaz
Aug 28, 2020Aspirant
I did what you suggested and it worked eventually. After the reset, I connected to routerlogin.net and it gave me the password reset page with the ability to set up the security questions. I set up the security questions and clicked "save". I then got an http "unknown error" and was unable to reconnect to routerlogin.net or routerlogin.com after multiple tries. I was doing this on a different PC ethernet connected to the router using Edge. I then downloaded Firefox because that worked on my other PC. I was then able to login using the admin password.
Aug 29, 2020Guru - Experienced User
Glad to hear you got it working! Even though it took a bit
