ML2021
Sep 13, 2021Aspirant
C6300 and C6300V2 modem crash
Summary: It looks like there is a software problem with the modem/router which will crash the system. After the crash, the system will go through an automatic reboot, and ISP reconnect. Detail: w...
Sep 14, 2021Guru - Experienced User
Something to contact NG support and let them know what your seeing.
The 6 series modems are somewhat getting to be older. You may want to check a newer model 7 series modem.
Good Luck.
ML2021
Sep 14, 2021Aspirant
I have just spend nearly two hours with Netgear techsupport. They refuse to recognize any problem with their design. I will now try to return the modem for a refund.
I do NOT recommend this modem for serious use.
