wg45678
Nov 30, 2015Aspirant
C6300 and Cable signal drops
Hello. Trying to resolve recurring issues with Medicom and my C6300, firmware version v1.02.21. My cable connection and internet access randomly drops. Here are the symptoms. 1) Modem connectio...
vkdelta
Nov 30, 2015NETGEAR Employee Retired
Hi,
Can you please post the power values? and full event log?
How do I obtain the event logs from a NETGEAR cable modem/modem router?
Link: http://kb.netgear.com/app/answers/detail/a_id/30008
How do I obtain the cable connection information from a NETGEAR cable modem/modem router?
Link: http://kb.netgear.com/app/answers/detail/a_id/30007
as soon as I see this message "Unicast Ranging Received Abort Response" , I see that reset was initiated from ISP side (Mediacom). also, if you have lot of uncorretables, that is another sign of RF issue from ISP.
We had a another community user from the same ISP with similar issue. he resolved the issue by removing unnecessary splitter(s) in his home.
DoS attack info is ok as it is an internal packet. You can ignore it.
- wg45678Nov 30, 2015Aspirant
Time stamp is apparently central time (1 hour ahead of local) despite being physcially located in AZ.
Power readings:
Apply Cancel Frequency start Value This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. Starting Frequency Startup Procedure Procedure Status Comment Acquire Downstream Channel 111000000 Hz Locked Connectivity State Ok Operational Boot State -- -- Configuration File -- -- Security Disabled Disabled Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables 1 Locked QAM 256 97 93000000 Hz 4.5 dBmV 40.3 dB 696507 764 2 Locked QAM 256 98 105000000 Hz 4.4 dBmV 38.9 dB 989711 300326 3 Locked QAM 256 99 111000000 Hz 4.1 dBmV 40.3 dB 819420 137 4 Locked QAM 256 100 117000000 Hz 3.9 dBmV 40.3 dB 855097 117 5 Locked QAM 256 101 123000000 Hz 3.5 dBmV 40.3 dB 963707 126 6 Locked QAM 256 102 135000000 Hz 3.9 dBmV 40.3 dB 18 0 7 Locked QAM 256 103 141000000 Hz 3.9 dBmV 40.3 dB 35 0 8 Locked QAM 256 104 147000000 Hz 4.0 dBmV 40.9 dB 32 0 9 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 10 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 11 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 12 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 13 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 14 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 15 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 16 Not Locked N/A N/A 0 Hz 0.0 dBmV 0.0 dB 0 0 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 30600000 Hz 47.8 dBmV 2 Locked ATDMA 1 5120 Ksym/sec 37000000 Hz 49.3 dBmV 3 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV 4 Not Locked N/A Unknown 0 Ksym/sec 0 Hz 0.0 dBmV Current System Time: Mon Nov 30 23:04:19 2015 - wg45678Nov 30, 2015Aspirant
Event Log part 1
Time Priority Description Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out
Event Log Part 2
Nov 30 01:14:01 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:02 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:02 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:02 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:02 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:03 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:03 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:03 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:03 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:04 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:04 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:04 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:04 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:05 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:05 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:06 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:06 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:06 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:06 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:07 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:07 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:07 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:07 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:08 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:08 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:09 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:09 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:09 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:09 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:10 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:10 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:10 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:10 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:38 2015 Critical (3) Unicast Ranging Received Abort Response - initializing MAC Nov 30 01:14:52 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:15:38 2015 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Nov 30 01:15:38 2015 Notice (6) TLV-11 - unrecognized OID Nov 30 15:40:18 2015 Critical (3) No Ranging Response received - T3 time-out - vkdeltaDec 01, 2015NETGEAR Employee Retired
there are so many timeouts and ranging abort messages request coming from ISP makes me believe this is an ISP issue rather than device issue.
which device were you using before?
- wg45678Dec 02, 2015Aspirant
This is the 1st cable modem with Mediacom. I was using VDSL from CenturyLink but their best offering was only 25Mbps down/0.8kbps up in my area. Need the higher cable modem speed (150Mbps down/25Mbps up) from Mediacom. IF it can become reliable.
