wg45678
Nov 30, 2015Aspirant
C6300 and Cable signal drops
Hello. Trying to resolve recurring issues with Medicom and my C6300, firmware version v1.02.21. My cable connection and internet access randomly drops. Here are the symptoms. 1) Modem connectio...
vkdelta
Nov 30, 2015NETGEAR Employee Retired
Hi,
Can you please post the power values? and full event log?
How do I obtain the event logs from a NETGEAR cable modem/modem router?
Link: http://kb.netgear.com/app/answers/detail/a_id/30008
How do I obtain the cable connection information from a NETGEAR cable modem/modem router?
Link: http://kb.netgear.com/app/answers/detail/a_id/30007
as soon as I see this message "Unicast Ranging Received Abort Response" , I see that reset was initiated from ISP side (Mediacom). also, if you have lot of uncorretables, that is another sign of RF issue from ISP.
We had a another community user from the same ISP with similar issue. he resolved the issue by removing unnecessary splitter(s) in his home.
DoS attack info is ok as it is an internal packet. You can ignore it.
wg45678
Time stamp is apparently central time (1 hour ahead of local) despite being physcially located in AZ.
Power readings:
| Frequency start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Current System Time: Mon Nov 30 23:04:19 2015 |
- wg45678Nov 30, 2015Aspirant
Event Log part 1
Time Priority Description Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out Nov 30 01:14:01 2015 Critical (3) No Ranging Response received - T3 time-out
