wg45678
Nov 30, 2015Aspirant
C6300 and Cable signal drops
Hello. Trying to resolve recurring issues with Medicom and my C6300, firmware version v1.02.21. My cable connection and internet access randomly drops. Here are the symptoms. 1) Modem connectio...
wg45678
Event Log Part 2
| Nov 30 01:14:01 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:01 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:02 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:02 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:03 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:03 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:04 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:04 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:05 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:05 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:06 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:06 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:07 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:07 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:08 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:08 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:09 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:09 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:10 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:10 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:14:38 2015 | Critical (3) | Unicast Ranging Received Abort Response - initializing MAC |
| Nov 30 01:14:52 2015 | Critical (3) | No Ranging Response received - T3 time-out |
| Nov 30 01:15:38 2015 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Nov 30 01:15:38 2015 | Notice (6) | TLV-11 - unrecognized OID |
| Nov 30 15:40:18 2015 | Critical (3) | No Ranging Response received - T3 time-out |
vkdelta
Dec 01, 2015NETGEAR Employee Retired
there are so many timeouts and ranging abort messages request coming from ISP makes me believe this is an ISP issue rather than device issue.
which device were you using before?
- wg45678Dec 02, 2015Aspirant
This is the 1st cable modem with Mediacom. I was using VDSL from CenturyLink but their best offering was only 25Mbps down/0.8kbps up in my area. Need the higher cable modem speed (150Mbps down/25Mbps up) from Mediacom. IF it can become reliable.
- vkdeltaDec 02, 2015NETGEAR Employee Retired
ah ok. Looks like there may some issue with RF. you should not be seeing so many timeouts and so many MAC Re-inits.
can you please call them fix the line?
- wg45678Dec 06, 2015Aspirant
i'll contact them again but I'm still not sure the modem is fault-free. I had an outage again yesterday. Cable modem event logs show the usual response as previously illustrated. However, in this case—as in all others—while the Modem's softwarwe shows the RF is missing the modem's cable connection and internet lights never go out. The modem fails to reconnect until I power cycle it (either by the switch or using the software reboot button in the advanced settings) and then the modem reconnects immediately on restart. This doesn't jibe to me if the RF conditions in the line have not changed in the time it takes to reboot.
