Net_Gear_Man
Apr 13, 2020Initiate
C6300 and NordVPN App on Windows 10 Pro (64 bit) PC
When I wrote to NordVPN tech'l support for steps to do to maximize speeds they replied: "Please search for a setting called "VPN passthrough" or "IPsec passthrogh" and enable it if it is present. Als...
Apr 13, 2020Guru - Experienced User
Maybe time to get into a modem unit and then find you a external router which would have better features and options for your VPN needs.
Some older modem router combo units maybe limiting on features they support.
CM series modems are modems only. R, RAX are NGs wifi routers and Orbi RBK systems are wireless MESH based router systems.
