DanYingling
Mar 01, 2017Aspirant
c6300 cable modem and router. and r7000 nighthawk dsl modem and router
I'm having internet issues. i have comcast cable internet and with the c6300 hard wired to computer my speed is around 236mbps download and around 15mbps upload. but on my xbox im only getting arou...
DarrenM
Mar 03, 2017Sr. NETGEAR Moderator
Hello DanYingLing
If other devices are getting full speeds have you tried to swap out the Ethernet cable or try to connect the xbox via wireless and see if its getting faster speeds?
DarrenM
DanYingling
Mar 03, 2017Aspirant
i have tried diffeent cables and wireless make no difference. tryed to set up port fowarding and idk if i did it right
but that didn't help either. wiped my xbox and reset router to factory spec. none of which did anything to help.
