mae1971
Oct 23, 2015Follower
c6300 cable modem router. Internet seems to be active but Wifi won't connect
My C6300 cable modem router has been working fine for the last 3 months and all of a sudden I dont have wireless connection. I have turn it on and off and spoke to comcast and my internet connec...
GreggerGear
Jan 18, 2016Aspirant
This happened to us recently too. I attribute it to our laptop that we upgraded to Windows 10. It would simply shut off the radios in our C6300 after it connected, even though all LEDs were still on. Other devices lost WIFI as a result. We rolled back to Windows 8.1 on the laptop and now all works well.
dlwintl
Jun 13, 2016Aspirant
Installed C6300 couple days ago and seems to be functioning ok, except wifi drops connectivity several times a day. Netgear support had me change channel on 2.4 and it worked for several hours but dropped again. So far, I've had to reboot C6300 each time to get wifi to work again. Ethernet and all other functions seems to be okay. On TWC so not sure if any relation to isp, but I don't think so since everything else seems to be working. Does anyone have idea how to resolve?
- DarrenMJun 15, 2016Sr. NETGEAR Moderator
Hello dlwintl
I would go back to your case you started with support in case there is some issue with the modems wifi they would be the ones that could replace the modem if needed.
DarrenM
