6300needhelp
Dec 08, 2020Tutor
C6300 cannot access 192.168.1.1 getting a timeout error.
Hi I am just trying to get into the gateway to update my network setting. The message I am getting for each are: error message took too long to respond 192.168.1.1 error mess...
Dec 08, 2020Guru - Experienced User
Try 192.168.0.1?
6300needhelp
Dec 08, 2020Tutor
I tried it is my orginial post.
I tried both
192.168.1.1
192.168.0.1
I even tried them in firefox and Internet Explorer
Please reread.
Thanks for your help!
- plemansDec 08, 2020Guru - Experienced User
try 192.168.100.1
that should be the modem side address
- 6300needhelpDec 09, 2020Tutor
This page isn’t working
192.168.100.1 sent an invalid response.
ERR_INVALID_HTTP_RESPONSE- antinodeDec 09, 2020Guru
> > Can you see which firmware version it's running now?
> Where do I find this information at?On the management web site page to which you can't get.
> ERR_INVALID_HTTP_RESPONSEThat's consistent with your getting that result from "192.168.0.1".
It should be the same C6300, hence the same management web site, so you
should see the same result at either address.I still suspect corrupt/misbehaving firmware. (Possibly caused by
bad hardware.) Whether _you_ can do anything about it is unclear. On a
DOCSIS gizmo like this, only the ISP can play with the firmware.
