6300needhelp
Dec 08, 2020Tutor
C6300 cannot access 192.168.1.1 getting a timeout error.
Hi I am just trying to get into the gateway to update my network setting. The message I am getting for each are: error message took too long to respond 192.168.1.1 error mess...
antinode
Dec 08, 2020Guru
> 192.168.1.1
I'd expect that. Not the default address for a modem+router.
> ERR_INVALID_HTTP_RESPONSE
> 192.168.0.1
That's the default address, so you are (still) communicating with the
C6300, but (obviously) not getting the expected result.
> [...] Reset my modem to the factory setting and I can get in [...]
Presumably at "192.168.0.1" or "192.168.100.1", or one of the
"routerlogin" names?
> [...] and change the password and update the security questions and
> then when I hit next it goes back to a timeout error.
"it goes back to a timeout error" or "it goes back to an
ERR_INVALID_HTTP_RESPONSE" error? If you retry the wrong address, then
a timeout would not be amazing.
If it works as expected after a settings reset, but then, after some
normal activity, starts misbehaving (when browsing to the same address),
then I'd say that the firmware is corrupt/misbehaving, causing the
management web server to get confused.
Could be a hardware defect, but I'd try to get the ISP to push
firmware to it (again?), and see if that changes anything.
Can you see which firmware version it's running now?
