6300needhelp
Dec 08, 2020Tutor
C6300 cannot access 192.168.1.1 getting a timeout error.
Hi I am just trying to get into the gateway to update my network setting. The message I am getting for each are: error message took too long to respond 192.168.1.1 error mess...
antinode
Dec 08, 2020Guru
> 192.168.1.1
I'd expect that. Not the default address for a modem+router.
> ERR_INVALID_HTTP_RESPONSE
> 192.168.0.1
That's the default address, so you are (still) communicating with the
C6300, but (obviously) not getting the expected result.
> [...] Reset my modem to the factory setting and I can get in [...]
Presumably at "192.168.0.1" or "192.168.100.1", or one of the
"routerlogin" names?
> [...] and change the password and update the security questions and
> then when I hit next it goes back to a timeout error.
"it goes back to a timeout error" or "it goes back to an
ERR_INVALID_HTTP_RESPONSE" error? If you retry the wrong address, then
a timeout would not be amazing.
If it works as expected after a settings reset, but then, after some
normal activity, starts misbehaving (when browsing to the same address),
then I'd say that the firmware is corrupt/misbehaving, causing the
management web server to get confused.
Could be a hardware defect, but I'd try to get the ISP to push
firmware to it (again?), and see if that changes anything.
Can you see which firmware version it's running now?
6300needhelp
Dec 09, 2020Tutor
firmware to it (again?), and see if that changes anything. Trying
Can you see which firmware version it's running now? Where do I find this information at?
Please see my comments in blue above.
