careys's avatar
careys
Tutor
Apr 06, 2019
C6300 Cannot change MTU size
Modem: C6300 Firmware: V2.01.26 ISP: Spectrum   Problem: Happens when I go into NetGear Genie (via either IE 11 or MS Edge) > Setup > WAN Setup.  When I modify the MTU Size (in bytes) and cli...
  • careys's avatar
    Apr 06, 2019
    Solved with workaround:  I checked the box for DMZ server and faked a DMZ server IP address, along with my MTU change. It saved both. Then I unchecked the box for DMZ Server and now just have the new MTU size.
    Oh well...
