7Of9
Dec 17, 2017Aspirant
c6300-Cant connect to main nettwork
For some reason I can't connect my new devices to my main network via WiFi. I'm only able to connect my new devices to the Guest network via Wifi only. Weird. I currently have old devices connected ...
DarrenM
Dec 20, 2017Sr. NETGEAR Moderator
Is the access control enabled? have you tried to put the device on the allow list?
DarrenM
7Of9
Dec 24, 2017Aspirant
I disabled the access control list and also I added the device in question to the access control list when it was activated. It's totally weird, all prior devices that where previously connected to the main have no issue connecting to the main even though I disconnect the device from the main and added it back to the main and it works. If I add any new device to the main it just gives me a bad password message and adding to Guest network it works ok.
- 7Of9Dec 24, 2017Aspirant
I'm thinking of doing a factory reboot and see it works. What a pain though.
