Revelation343
Oct 01, 2018Follower
C6300 Connectivity Issues (Mediacom)
Posting this to try to determine if I am actually receiving a DoS attack and if there's anymore troubleshooting I can do on my end waiting for my ISP to respond to a service call scheduled on October 9th. I have a 100Mbps line, but I'm only getting between 1-5 down and .5-1 MBps up at any given time.
I'm also receiving every 10 mintues exactly the following notification in Logs:
| [DoS attack] ICMP Flood from fe80:0000:0000:0000:96d4:69ff:fe55:3019 |
I am just wondering if this is a false positive, I do not know much about IPV6 addresses but it says Local-Link when I try to resolve the IP.
| Firmware Version V2.01.18
| <tabindex=-1>Startup Procedure | ||||||||||||||||||
<tabindex=-1>Downstream Bonded Channels
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | UnCorrectables |
| 1 | Locked | QAM 256 | 1 | 111000000 Hz | 5.5 dBmV | 38.9 dB | 0 | 0 |
| 2 | Locked | QAM 256 | 2 | 117000000 Hz | 5.1 dBmV | 40.3 dB | 7 | 0 |
| 3 | Locked | QAM 256 | 3 | 123000000 Hz | 5.3 dBmV | 40.3 dB | 0 | 0 |
| 4 | Locked | QAM 256 | 4 | 129000000 Hz | 4.6 dBmV | 38.9 dB | 6 | 0 |
| 5 | Locked | QAM 256 | 5 | 147000000 Hz | 4.0 dBmV | 38.9 dB | 5 | 0 |
| 6 | Locked | QAM 256 | 6 | 153000000 Hz | 4.1 dBmV | 40.3 dB | 0 | 0 |
| 7 | Locked | QAM 256 | 7 | 159000000 Hz | 3.7 dBmV | 40.3 dB | 0 | 0 |
| 8 | Locked | QAM 256 | 8 | 165000000 Hz | 3.9 dBmV | 38.6 dB | 5 | 0 |
| 9 | Locked | QAM 256 | 9 | 171000000 Hz | 3.7 dBmV | 38.9 dB | 0 | 0 |
| 10 | Locked | QAM 256 | 10 | 177000000 Hz | 3.7 dBmV | 38.9 dB | 0 | 0 |
| 11 | Locked | QAM 256 | 11 | 183000000 Hz | 3.9 dBmV | 38.6 dB | 0 | 0 |
| 12 | Locked | QAM 256 | 12 | 189000000 Hz | 3.4 dBmV | 38.9 dB | 0 | 0 |
| 13 | Locked | QAM 256 | 13 | 195000000 Hz | 3.5 dBmV | 40.3 dB | 0 | 0 |
| 14 | Locked | QAM 256 | 14 | 201000000 Hz | 2.7 dBmV | 38.9 dB | 6 | 0 |
| 15 | Locked | QAM 256 | 15 | 207000000 Hz | 2.2 dBmV | 38.6 dB | 0 | 0 |
| 16 | Locked | QAM 256 | 16 | 213000000 Hz | 0.9 dBmV | 38.9 dB | 0 | 0 |
<tabindex=-1>Upstream Bonded Channels
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 3 | 5120 Ksym/sec | 20750000 Hz | 38.8 dBmV |
| 2 | Locked | ATDMA | 2 | 5120 Ksym/sec | 28250000 Hz | 38.8 dBmV |
| 3 | Locked | ATDMA | 1 | 5120 Ksym/sec | 35750000 Hz | 38.8 dBmV |
| 4 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
Current System Time: Mon Oct 1 05:23:48 2018
1 Reply
- vkdeltaNETGEAR Employee Retired
have you checked speeds via wired connection?
