Rashiev
Jul 21, 2019Guide
C6300 connectivity issues
Having major issues with Comcast internet, massive slow downs and random reboots. Only 15 channels downstream are locked, channel 16 won’t when it did before. Only 3 out of 4 upstream and bonded and ...
- Jul 29, 2019
Glad they figured it out.
Please mark your post as solved.
Enjoy. :smileywink:
Jul 21, 2019Guru - Experienced User
If you pull up your connections page and get a screen capture of your that it helps. Plus capturing the logs for us. These can tell us signal strength, signal to noise ratio, problems in the logs, etc. Please post those here.
I do recommend checking all your connections coming in the house for corrosion, loose connectors, cheap cable/connectors. This can cause issues.
Rashiev
Jul 21, 2019Guide
