Rashiev
Jul 21, 2019Guide
C6300 connectivity issues
Having major issues with Comcast internet, massive slow downs and random reboots. Only 15 channels downstream are locked, channel 16 won’t when it did before. Only 3 out of 4 upstream and bonded and ...
- Jul 29, 2019
Glad they figured it out.
Please mark your post as solved.
Enjoy. :smileywink:
Jul 21, 2019Guru - Experienced User
Contact your ISP and have them look into this with you. They need to ensure the signal levels up to the modem are good.
Be sure there isn't any coax line splitters between the modem and the ISP service box.
Rashiev wrote:Having major issues with Comcast internet, massive slow downs and random reboots. Only 15 channels downstream are locked, channel 16 won’t when it did before. Only 3 out of 4 upstream and bonded and locked.
- plemansJul 22, 2019Guru - Experienced User
echoing what FURRYe38 said. Check with your isp. it looks like signal issues. I'd remove all splitters/amplifiers and move the modem as close to where your isp's line comes into the house. This reduces the chances one of your devices are causing the error. Some isp's charge for problems within the house and if you can reduce that chance, its cheaper for you.
- RashievJul 29, 2019Guide
It was something with my isp. Modem acquired a different starting frequency and I haven’t had low snr or any other issues. They of course kept telling me everything was fine on their end.
- FURRYe38Jul 29, 2019Guru - Experienced User
Enjoy. :smileywink:
