rlheczko50's avatar
rlheczko50
Follower
May 31, 2017
C6300 Default Gateway being assigned with private IP address
My C6300 is not giving off any wireless. My SSIDs are not showing up on my laptop or phone. I can connect using an ethernet connection to my laptop. Tried activating it with my cable provider. They say its fine on their end. Here are my settings. Please someone help. I know the IP address and default gateway are wrong.
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : new.rr.com
IPv6 Address. . . . . . . . . . . : 2605:a000:afc0:3:5868:725d:73f2:10de
Link-local IPv6 Address . . . . . : fe80::85c9:6bfb:ac65:9d9e%12
IPv4 Address. . . . . . . . . . . : 174.102.191.114
Subnet Mask . . . . . . . . . . . : 255.255.240.0
Default Gateway . . . . . . . . . : fe80::201:5cff:fe8a:bc46%12
174.102.176.1
Tunnel adapter isatap.{0275D7EB-018E-4CFC-811B-CDDE1BF779DC}:
Tunnel adapter isatap.new.rr.com:
Tunnel adapter iphttpsinterface:
IPv6 Address. . . . . . . . . . . : fd66:46fc:efe2:1000:1fa:c1b3:4274:21e
Temporary IPv6 Address. . . . . . : fd66:46fc:efe2:1000:2d7e:6069:1939:c1e4
Link-local IPv6 Address . . . . . : fe80::1fa:c1b3:4274:21e%22
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello rlheczko50
    Have you checked the button on the front of the modem that turns the wireless off? Have you tried to factory reset the modem?
    DarrenM
