indijones
Sep 25, 2018Aspirant
C6300 Dropped all connections (wifi & LAN)
My internet is with comcast and have been using this router (own) for the last two years without any glitch. This afternoon I lost all wifi & LAN connections suddenly. Tried power off/on & event fact...
antinode
Sep 25, 2018Guru
> [...] I even tried to connect to the router admin
> (192.168.0.1)directly by connecting an ethernet cable between the router
> and a laptop butgot the message that it couldn't be reached. [...]
What is this "a laptop", and what is its (Ethernet) IP address when
you do this stuff? "connect" using some web browser or other?
- indijonesSep 25, 2018Aspirant
I connected the LAN port of the laptop to one of the LAN ports of the router, opened a web browser and typed 192.168.0.1. For the laptop's ip address, I tried both auto and fixed addresses. I even checked the laptop's ip address using ipconfig /all and each time it showed a valid ip address.
- antinodeSep 25, 2018Guru
> router, [...]
And the relevant port-status LED indicator(s) did what?
> [...] I tried both auto and fixed addresses. I even checked the
> ip address.
So, your "a laptop" runs some version of Windows? That report would
be even more interesting if I could see any of the actual IP addresses
to which you refer. (Sadly, with my weak psychic powers, ...)
As usual, showing actual actions with their actual results (actual
commands with their actual output, error messages, LED indicators, ...)
can be more helpful than vague descriptions or interpretations.
Copy+paste is your friend.
