KenSimmons
Jun 13, 2018Aspirant
C6300 dropping Wifi connection
I haven't found any solutions on the forum and this seems to have been a problem for years now. I have the latest firmware from suddenlink, and everything seems to be in check. My C6300 will drop i...
Jun 13, 2018Guru - Experienced User
You've posted this in the wrong place (ReadyNAS) - I've moved it for you.
Do you have any ethernet devices connected? If so, do they lose connectivity when the WiFi drops?
Also, are you losing the SSID on both bands (2.4 ghz and 5 ghz), or only one?
KenSimmons
I am only using wifi connections with my desktop and my phone. The desktop is only 2.4ghz capable but my i-Phone loses 5g as well, so yes, I am losing both bands.
The disconnects seem to be infrequent - at times the connection will only last a few seconds before a restart, but as of this post I can last up to 20-30 minutes. Another factor that seems to trigger a failure to broadcast is connecting to certain high traffic sites/games.
I can send a list of system specifications but for now here are the ip v4 ping test, ip v6 ping test and event log from the router page.
PING 192.168.0.1 (192.168.0.1): 64 data bytes
72 bytes from 192.168.0.1: seq=0 ttl=64 time=0.000 ms
72 bytes from 192.168.0.1: seq=1 ttl=64 time=0.000 ms
72 bytes from 192.168.0.1: seq=2 ttl=64 time=0.000 ms
--- 192.168.0.1 ping statistics ---
3 packets transmitted, 3 packets received, 0% packet loss
round-trip min/avg/max = 0.000/0.000/0.000 ms
PING 2001:192:168:0::1 (2001:192:168::1): 64 data bytes
ping6: sendto: Network is unreachable
| Jun 13 2018 08:35:36 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Time Not Established | Error (4) | Primary lease failed, IPv4 fallback initiated |
| Time Not Established | Critical (3) | DHCP failed - RS sent, no RA received |
| Jun 13 2018 08:25:55 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out |
| Jun 13 2018 07:37:22 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Jun 13 2018 06:44:07 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Jun 13 2018 06:11:26 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Time Not Established | Critical (3) | TFTP Request Retries exceeded, CM unable to register |
| Time Not Established | Critical (3) | TFTP failed - Request sent - No Response |
| Time Not Established | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync |
| Time Not Established | Warning (5) | ToD request sent - No Response received |
| Time Not Established | Warning (5) | Lost MDD Timeout |
- DarrenMJun 14, 2018Sr. NETGEAR Moderator
You do seem to have alot of T3 timeouts which is typically a issue with the ISP. you may want a tech to come out and check the cable lines.
DarrenM
