cfocats
Nov 06, 2017Aspirant
C6300 Drops Wifi every month
I am on TWC/Spectrum and Modem loses WIFI , both 2.4 and 5G once a month and a reboot or power restart fixes the issue. The Firmware is changed when this happens to 2.01.18 and after I reboot unit, f...
vkdelta
Nov 06, 2017NETGEAR Employee Retired
FW should not go back and forth. Are seeing that? It should be on 2.01.22 or higher.
how often can you see the issue?
- cfocatsNov 06, 2017AspirantHappens once a month and when it does I lose WiFi I look at the router and I see that the firmware is at. 18 and then I reset the router or power reset and it goes back to. 22
