KBarOKC
Feb 10, 2015Novice
C6300 DynDNS access problem
I can not login via iPhone app to a couple of local services (CCTV & Security) on my network via the C6300's wifi while using my dns address (example johndoe.dipmap.com). The services work fine when ...
Retired_Member
Feb 13, 2015I am having a similar problem. I can access my camera NVR from my dyndns externally, but when I enter host name in my home on the 192.x network, it resolves to the router instead of the camera NVR.
I should point out, I'm using uPNP to successfully get through necessary port over the internet.
