Dirkddw
Jan 15, 2019Aspirant
C6300 Ethernet port not working
I have the C6300 and set it up and all ethernet ports worked. The next day my security NVR was not reachable. I determined that IP the device now showed was 192.168.1.10. My range is 192.168.0.10 ...
Dirkddw
Jan 16, 2019Aspirant
WOW! HIt me some more while I am down. If I were an expert on this I would not be asking for help.
Nodism1125
Jan 16, 2019NETGEAR Expert
Hi Diskddw,
If you already modify the IP settings of NVR within the same IP range of the Cable modem/router, you need to test first.
Connect the computer wired to NVR.
Assign the static IP address in range of the 192.168.1.x over LAN
Check if you can ping the new IP address
Check if you can access the NVR configuration page
Another way, changing the C6300 IP DHCP in range of the NVR 192.168.1.x network.
