Dirkddw
Jan 15, 2019Aspirant
C6300 Ethernet port not working
I have the C6300 and set it up and all ethernet ports worked. The next day my security NVR was not reachable. I determined that IP the device now showed was 192.168.1.10. My range is 192.168.0.10 ...
Dirkddw
Jan 16, 2019Aspirant
WOW! HIt me some more while I am down. If I were an expert on this I would not be asking for help.
antinode
Jan 16, 2019Guru
> [...] If I were an expert on this I would not be asking for help.
I didn't ask for your expert opinion on anything. What I asked for
were accurate descriptions of what you saw, and what you did, and what
happened when you did it. The _problem_ is that you present your
analysis of these things, rather than simply reporting them, and you
apparently don't know enough to do that analysis.
For example, "my security NVR". How tough would it be to reveal a
maker and model number? Or, "How is it connected to your C6300
modem+router? Wired? Wireless?" What's tricky about that? Look for
"?". Answer the questions.
