drlswat13
Aug 26, 2018Follower
C6300 finding network security key
Trying to setup my new HP Laptop and it is asking for the network security key (not my network password key) which I can not find. Can someone help with this
Thanks Dan
michaelkenward
Aug 27, 2018Guru - Experienced User
The term "security key" is usually used to describe the wifi password.
Tell us what you are trying to do and you might get better replies.
By the way, you have posted your message in the section of this community given over to R6000 Series AC WiFi Routers. Your devices is a Cable Modem. You might do better here:
