kkomenda
Jul 09, 2016Aspirant
C6300 Firmware Update to V2.01.14 -- Timing and Connectivity Issues
Based on the C6300 Event Log, it looks like my C6300 automatically updated its firmware to V2.01.14 on July 7. Since that time, I have had non-stop connectivity issues with Time Warner Cable. I ...
- Jul 16, 2016
I believe that I solved my own problem. The issue was not with the router firmware at all. Instead Windows 10 automatically downloaded and installed a piece of adware/bloatware onto my Acer laptop called "Acer Explorer". It appears to be a valid program, just not very well designed. The program was downloaded/installed on July 7, and every so often it would launch and flood the router WiFi with so much traffic that the router would simply shut down.
I kept the laptop off the network for a week and had zero router problems. I re-connected it the laptop via WiFi, and the router failed within 15 minutes.
The mechanics of the issue are probably much more nuanced than that, but removing the Acer Explorer program resolved the problem. I've had the laptop on the WiFi for six hours with no problems.
kekolily
Hi,
I am also having the same isue with my Netgear but I am on Comcast. I keep getting slower internet and skipping when I am steaming netflix. If anyone finds out how to fix this please post.
- VE6CGXJul 09, 2016Master
If older firmware worked fine, logic tells me to revert the update.
