fearandloath
Jan 10, 2018Star
C6300 firmware update
I discovered that my R6300 Modem/Router is in need of a firmware update. By all accounts I can not do this myself in the usual fashion and everything I am reading says that my ISP must do the update....
- May 01, 2018
@Belcantor Looks like the issue you have is a minor bug that has been fixed and will be available in next FW release once Comcast has approved it and pushes it out. In the meantime there is a work around you can use to address. So in order to avoid issues with DNS you need to make sure all 3 DNS fields are filled out.
Workaround for C6300 Minor DNS Bug:
1. Log into your C6300
2. Go to Advanced > Setup > Internet Setup
3. On Internet Setup page select Use these DNS Servers.
4. Fill in Primary, Secondary and Tertiary DNS server boxes.
5. For Primary and Secondary DNS use Comcast DNS and for Tertiary either copy the 2nd DNS server to it or use 8.8.8.8 or 8.8.4.4 or 1.1.1.1 or 1.0.0.1. For best performance and security you probably want to use the Cloud Flare DNS 1.1.1.1 or 1.0.0.1
6. Once all the DNS settings have been specified click apply and you should be good to go.
PS: If you need more info on 1.1.1.1 and 1.0.0.1 DNSs you can see it here https://1.1.1.1/
concerned_user
May 30, 2018Tutor
Hello,
I am also having this issue. I had a conference call with Cox Communications and a Netgear representative and neither side was able to provide a solution. Since I own the modem Cox stated that they will not provide the update becuase if my modem became unresponsive then they would be responsible for its replacement. The C6300 has no options for the user to push a firmware update and this is a glaring security issue for this device. Has Netgear been able to resolve this issue in any way? There are no options in the GUI to check for a firmware update and visiting the support site for the C6300 reveals no solotuions for this issue.
-Concerned User
zoranav
May 31, 2018Aspirant
C6300 became a very expensive paper weight. Ended up purchasing Arris SB8200 modem and new Linksys Velop mash. Speeds are now back to over 100 M. Never to purchase another NETGEAR product again.
