fearandloath
Jan 10, 2018Star
C6300 firmware update
I discovered that my R6300 Modem/Router is in need of a firmware update. By all accounts I can not do this myself in the usual fashion and everything I am reading says that my ISP must do the update....
- May 01, 2018
@Belcantor Looks like the issue you have is a minor bug that has been fixed and will be available in next FW release once Comcast has approved it and pushes it out. In the meantime there is a work around you can use to address. So in order to avoid issues with DNS you need to make sure all 3 DNS fields are filled out.
Workaround for C6300 Minor DNS Bug:
1. Log into your C6300
2. Go to Advanced > Setup > Internet Setup
3. On Internet Setup page select Use these DNS Servers.
4. Fill in Primary, Secondary and Tertiary DNS server boxes.
5. For Primary and Secondary DNS use Comcast DNS and for Tertiary either copy the 2nd DNS server to it or use 8.8.8.8 or 8.8.4.4 or 1.1.1.1 or 1.0.0.1. For best performance and security you probably want to use the Cloud Flare DNS 1.1.1.1 or 1.0.0.1
6. Once all the DNS settings have been specified click apply and you should be good to go.
PS: If you need more info on 1.1.1.1 and 1.0.0.1 DNSs you can see it here https://1.1.1.1/
fearandloath
May 15, 2018Star
Trey,
Sorry you are having this problem also. I am sure there are a lot of us out there. It's a shame we have to spend our hard earned money to replace a fairly new product just because the company can't guarantee a simple update. Now I will always be buying my modem/router through the cable company and never a retail store. Expensive lesson learned.
ktob
May 31, 2018Aspirant
I had long talk with Netgear support. They stated that netgear has supplied firmware that will work. Xfinity spent 4 houra at my home and downloaded the firmware many times. The netgear c6300 still qould not connect. I think that all people who have experienced this shoumd get together and take action. These companies should not be allowed to get away with this kind of service. For myself i will be asking for a return if the money i paid for the useless product. A ckass action would be a better approach. I hope with this type of service netgear goes out of business. Maybe their competitors should offer a discou nt if we turned in out netgear product and bought theirs.
- concerned_userMay 31, 2018Tutor
I also have a very nice Arris Cable Modem / WiFi combo router and when I checked the GUI interface I wasn't able to update that device's firmware either. Are there any devices out there that can be udpated by the user? We shouldn't be forced to lease a router from our ISP.
- fearandloathJun 01, 2018Star
Netgear claims this is across the board with all cable modems. However several reps from my cable company claim they have never heard of such a thing. So who even knows what to believe. And I believe Netgear is having it's own special problems with their updates. I understand the point of the cable company not updating equipment that is not theirs. But if I buy a modem over the counter I believe it should then have a disclaimer about updates. Of course sales would go horribly down so it's easier to keep the customer in the dark and keep profits rolling in.
I finally broke down and purchased, rather than leased, a modem/router from my cable company. It pained me to give more money to them but it was good, fairly priced Arris equipment. And at least it gets the updates it needs.
