ThoughtA
Sep 21, 2015Aspirant
C6300 Frequent Disconnections with Comcast
I've been having a similar (but still different) issue as this thread. However, I do not have an additional AP, and my issue occurs over ethernet as well. To save you reading a different thread, ...
ThoughtA
Sep 22, 2015Aspirant
Weird. I could swear I had responded to this. Thanks for the suggestion! I made that change several hours ago, but I haven't really been here to monitor it. I'll let you know if it helps at all.
Thanks again!
ThoughtA
It looks like I'm unable to edit my posts. I apologize if I'm missing how to do that. I've had at least one micro disconnection since my previous post saying that I'd changed my DNS settings. I suspect this will end up not resolving the issue.
Comcast is sending me a gateway and a splitter so I can test both routers at the same time. Hopefully that will yield results. I'm still open to suggestions here, of course! I'll update anything else I find out.
- DarrenMSep 23, 2015Sr. NETGEAR Moderator
Hello ThoughtA
Ok let me know how the other modem goes Im still looking into stuff to try to fix this.
DarrenM
