Swift120
Mar 09, 2022Guide
C6300 Frequent short internet drops
I have a C6300 modem/router with Xfiinity cable internet. I have used this exact set-up for several years without any issues, but over the last few weeks my internet has been pretty bad. A...
- Mar 17, 2022
Just wanted to give an update. I switched to a Motorola MB7621 (24x8 DOCSIS 3.0) modem and another router (an old TP Link that I borrowed) without changing/replacing anything in the coax line. That solved the problem immediately. My guess is the old C6300 modem-router hardware was failing.
Swift120
Mar 09, 2022Guide
ISP has checked signal up to the modem and verified cable and connection quality. There is no splitter installed. Power off for 1 minute and back on didn't make a difference.
Connection page:
| <tabindex=-1>Startup Procedure</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Current System Time: Wed Mar 9 16:46:52 2022 | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| System Up Time: 5 days 06:18:49 |
Mar 09, 2022Guru - Experienced User
A tad bit low on power however with in spec.
Though are you getting some correct and uncorrectables that should be zero on 4, 5 and 6.
Check for loose connections. Make sure all coax jack plugs are screwed in firmly.
Had a factory reset and setup from scratch been performed?
- Swift120Mar 09, 2022Guide
Yes, verified all connections and factory reset has been performed. Using standard settings now, so no setup after factory reset.
- FURRYe38Mar 09, 2022Guru - Experienced User
OK see if this happens again. Possible you might need a new modem...
Still happening unfortunately.
I also had my laptop ping the router to see if it was still reachable during an outage. During the outage there were no sucessful pings. Instead, most pings didn't receive a reponse, and a few resulted in "Destination Host Unreachable". I did not get any "Network is unreachable", which it gives if the wifi is getting disconnected.
My interpretation would be that there is something going wrong in the modem-router, since just bad cable connection (like a bad coax) shouldn't affect the LAN. So time to buy a new modem-router?
