SeaDude
Sep 12, 2015Aspirant
C6300 IP Address Reservation Not Working
Hello, I am unable to reserve an IP address using "LAN Setup" then the "Add" button under "Address Reservation". When I click "Add", I get a progress bar at the top that says "Updating Settings"...
- Nov 26, 2016
I was able to access the list of devices after disabling the Guest network. Thanks for the tip.
I was thinking that maybe I had a conflict with a device. I was going to unplug and disconnect everything except the device I wanted to add a reservation for as my next step.
Keltik79
Jul 28, 2016Aspirant
I'm having the same issue. I've tried different browsers and rebooted my modem/router and still cannot assign my IP address. I have guest network turned off and I have firmware version 1.02.20 from Cox Communications.
DarrenM
Aug 01, 2016Sr. NETGEAR Moderator
Hello keltik79
When you try to save address does it just not save after you click add? Have you tried to do this using another device?
DarrenM
