SeaDude
Sep 12, 2015Aspirant
C6300 IP Address Reservation Not Working
Hello, I am unable to reserve an IP address using "LAN Setup" then the "Add" button under "Address Reservation". When I click "Add", I get a progress bar at the top that says "Updating Settings"...
- Nov 26, 2016
I was able to access the list of devices after disabling the Guest network. Thanks for the tip.
I was thinking that maybe I had a conflict with a device. I was going to unplug and disconnect everything except the device I wanted to add a reservation for as my next step.
DarrenM
Sep 14, 2015Sr. NETGEAR Moderator
Hello SeaDude
Are you able to try a different browser to see if you are getting the same results? also you may want to check and make sure a pop up blocker or ad block is not causing a issue when you go to save your settings. Hope to hear your feedback.
DarrenM
- SeaDudeSep 14, 2015Aspirant
Thanks for the response. Yes, tried Firefox and Chrome; both wireless gui access and cabled. I don't have any popup or adblockers on.
Thoughts?- SeaDudeSep 14, 2015Aspirant
On a whim... I disabled my guest network and was able to successfully add reserved IP addresses.
I was sure to hit "apply" after each IP was reserved.
Worked like a charm! Hope this helps others fix the problem!
- Diver4242Sep 26, 2015Aspirant
My guest network is off and I stil have this problem. Firmware V1.02.21 and I can't reserve any addresses, the table is empty and I get the same thing here, just a page not found. Tried it on IE and Firefox on Windows 7. Very frustrated, I need to reserve addresses for two wireless printers.
