clintonef9's avatar
clintonef9
C6300 No Internet
Hello, I've owned the Netgear C6300 for not even a year and it won't connect me to the internet. All of my devices dropped off at once, wireless and wired. This happened before and I had to restore the modem to factory settings.
I called Netgear this time(I think its weird I would have to keep resetting it to factory and hopefully there's another way) and they told me it needed to be setup correctly. Of course since it's past the tech warranty(3 months and i bought the device in December) I have to pay for it.
I've never messed with the settings but I am willing to try and fix it if I can get some guidance.
1 Reply
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Clintonef9
    You should need much setup just need to set the wireless settings by changing the password and setting the SSID.
    DarrenM
