TJEwing
Sep 18, 2017Aspirant
C6300 not able to reach ipv4 sites, but only ipv6 sites
Started using my C6300 at a new home with Xfinity/Comcast cable in May 2017. About two days ago (mid-September 2017), we couldn't reach most sites and received 'server can not be found' or 'inter...
- Sep 20, 2017Hi, I tried a hard reset of my modem back to factory settings, which worked. I had to resetup my wifi network, but a small price to pay for working internet. Good luck
Tj
TJEwing
Sep 20, 2017Aspirant
Tj
Tj
BaxterB23
Sep 24, 2017Aspirant
Hey there, it seems a few people have experienced this issue over the last couple of days. I too have the C6300 and Xfinity and Xfinity said everything is fine on their end.
I can't access netgear routerlogin.net because of the issue. How did you factory reset the modem/router? I tried a safety pin on the Reset button on the back but it just rebooted the device with all the same wifi networks etc
- DarrenMSep 26, 2017Sr. NETGEAR Moderator
You will need to hold the reset button for 10+ seconds to do a factory reset.
DarrenM
