ChipsDestroyer
Nov 02, 2017Follower
C6300 Not Broadcasting WiFi
As the title states, my modem-router is not broadcasting a WiFi signal. I registered my device with my ISP and everything is working on their end. I'm getting service, as my computer is currently har...
antinode
Nov 02, 2017Guru
> [...] I've tried logging in via http://routerlogin.net or
> http://192.168.0.1 and it says that I need to be connected to the WiFi
> signal from my device to login in to the device.
Welcome to what may be the worst error message in the world. For an
explanation, try:
https://community.netgear.com/t5/x/x/m-p/1365830
Briefly, the idea is that "[www.]routerlogin.net" should point to
your own router, but that's true only if you use your own router for DNS
name resolution. Irregardful, you should be able to get to the thing
using its IP address, if you can determine (or guess) that.
I don't see how you can get to that page if you specify the router's
IP address. Knowing what "my computer" is might help in deciding how to
determine the router's IP address. You can often get it from your
computer's IP configuration as the default gateway or router address (or
some similar description).
