tlluke
Mar 21, 2017Aspirant
C6300 Periodic Disconnects
I have a C6300 cable modem/router in a vacation home, with only 2 Honeywell wifi thermostats and a Chamberlain wifi garage door opener connected via wifi when the home is not occupied. Since it was in...
tlluke
- DarrenMMar 29, 2017Sr. NETGEAR Moderator
Hello Tluke
Are you able to post the logs from the modem when these disconnects are happening.
DarrenM
- tllukeMar 30, 2017Aspirant
Hi DarrenM,
Thanks for your reply. I will be at the property with the router this weekend and will try to download and post the logs.
Tlluke
- tllukeApr 03, 2017Aspirant
Hi DarrenM,
I am at the site with the router, but unfortunately am not able to provide the logs. I don't have a desk top or laptop, just a notebook and phone. I was not able to figure out how to access the log using the Netgear app, so I logged into the router using my router. I found the log, but was only able to scroll back 3 days and the last event was about a week ago. I did find, however, that my firmware version is V1.02.21, which does not appear to be current. I purchased this router myself, it was not provided by my cable company. Does my firmware need to be updated? If so, how do I do that? Thanks!
- DarrenMApr 05, 2017Sr. NETGEAR Moderator
Hello tlluke
You can not update the firmware all firmware for cable modems is pushed via the isp automatically.
DarrenM
