samrash
Sep 28, 2015Follower
c6300 port forward not working
I had old cable modem and my router had supposedly given up, so I bought netgear c6300 cable modem and router. I have done the port foward setup similar to how I had in the past, but it is not workin...
tsaltzma
Jul 07, 2016Aspirant
Firmware version is 2.01.14.
- DarrenMJul 07, 2016Sr. NETGEAR Moderator
Hello tsaltzma
This issue should be fixed in this firmware are you using address reservation and then forwarding the ports? Does it allow you to enter your ports and they do not work or is it not saving the info you enter at all?
DarrenM
